Results 1 to 9 of 9
Thread: Powering a USB Hub ...?
    Anodized 0m3g4's Avatar
    Apr 2007
    Ohio, USA
    Question Powering a USB Hub ...?
    Hey guys.
    I've got a USB hub-related question. Is it possible to power a USB Hub on batteries? To do this, I need to plug in a bus-powered USB hub to a self-powering USB hub. (I checked out the USB Hub Wiki page)
    So, about my question. The hub I need to power requires 5V. (That's what the little label above the power adapter port says) The hub didn't come with a power adapter cord.
    Anyone know of a way to do this? Thanks in advance.
    Oh, and if anyone needs anymore information, just say so.
    Last edited by 0m3g4; 08-03-2007 at 06:40 PM. Reason: Forgot a little detail. >_<;
    Current Project: n/a (Coming real soon though)
    t3h f3cKiN 33Ji7 calumc's Avatar
    May 2007
    Co. Sligo, Ireland
    Default Re: Powering a USB Hub ...?
    it would be possible but problems may arise from the voltage of the batteries dropping. because even if you had a 5v battery it wouldnt stay at 5v for very long
    Quote Originally Posted by Crazy Buddhist View Post
    I'm starting to worry that I may become genuinely funny at some point. Then there will be no hope.
    Apr 2007
    Ohio, USA
    Hmm. That's true.
    I know this is a weird theory, but would it be possible to power it by another USB cord? So, two cords going into the PC, not one.
    Jan 2006
    Normal
    USB ports put out 5V, so I think you could.
    May 2007
    Co. Sligo, Ireland
    why cant you just use a power cable again?
    Apr 2007
    Ohio, USA
    Alrighty. Here's my plan.
    I'm planning to link together two USB Hubs. But, one requires it to be powered. (Check my first post! :p)
    It's basically to make an 8-port hub. Now that I think of it, couldn't I just plug in both hubs to the PC? Wooooooooow, dumb moment.
    Both of these hubs (or the one big one) will be contained in a "Project Box." Yeah, one from Radioshack. Anyways, this will power a Linux Leech (refer to this Instructable, not by me. It's a great tutorial though!) and it serve as a Hub for my Project HRG. Confusing, but I'm not real sure how else to explain it.
    If anyone needs anymore info, just say so.
    Jan 2006
    Normal
    Just to be sure, how many amps are supplied by the power cable?
    Apr 2007
    Ohio, USA
    Not sure? The hub didn't come with one. It has the option to be supplied by power by one though.
    SOB Fettler xmastree's Avatar
    Burnley, Lancs. UK
    Quote Originally Posted by 0m3g4 View Post
    Are you sure it needs a power supply? I've never seen one which doesn't work without.
    I have a powered hub, which is fine for things like my external hard drive which draws more current than my laptop's port can supply. The hub works fine without its psu for card readers or thumbdrives.
    Quote Originally Posted by aintnothang View Post
    Think of a way to simulate a real bullet hole, like shooting it.
