Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: How To Turn a Mini Maglite Into a Laser
  1. #21
    Jun 2007
    look behind you
    Default Re: How To Turn a Mini Maglite Into a Laser
    Edit:... Damnit. I have 2 lasers, and I don't know which is for reading and which is for writing. I guess I'll just try both out, eh?
    use the red laser!!!!
    the other one is an IR laser and will burn ur eyes out without you even knowing!!!
    you can thank me later for saving ur vision
    I would mount it on my hubcap, and burn through the tires of all the cars attempting to pass me.. very james bond like.
    can u actually do this cause i am only a minor and i am trying to squeeze in all illegal activity before i turn 18
    If I make one, it will be for practical uses, not as a weapon, I've had my taste of court and that was too much.
    continue.....
    OPP Transformers Case / Dangerously 1337 / Hell's Regect
  2. #22
    Jun 2006
    The Dairy State...
    Quote Originally Posted by lukeisthecoolest
    Yeah, 'cause nobody is arrested before they're 18
    Anyone know how I can test the lasers before I put them in the flashlight? I tried one with a AA battery, but nothing happened.
    RIP Bucko
  3. #23
    Remember Remember, The 5th Of November.
    Jul 2007
    look directly into it and to make sure its not IR, if its IR you'll see the smallest bit of light showing
  4. #24
    read my comic already! (sig) xRyokenx's Avatar
    Dec 2006
    Bloomingburg, NY
    Quote Originally Posted by D1337 View Post
    Lol, yeah, that's gonna happen.
  5. #25
    I mod everything I touch. Indybird's Avatar
    Nov 2005
    Michigan
    I've always wanted to get a Wicked Laser, but they're expensive as hell. This looks like it has the same power, so I'm definitely going to try this.
    -Indybird
  6. #26
    Since 2006 DaJe's Avatar
    Aug 2006
    Massachusetts
    I myself have a green laser. I have two burners I could rip apart to make this. One is an old 8x, and the other I believe is 18x, and is also a lightscribe burner. If I had to destroy one, I would rather it be the 8x one. I'm just not sure how powerful the laser is in it though. Any ideas?
  7. #27
    Jun 2006
    The Dairy State...
    Quote Originally Posted by DaJe View Post
    It shouldn't be too weak, and I mean, either way it will have some effect on what you point it at.
    Also, just a tip for anyone doing this, you'll need a #0 Philips head screw driver. The screws around the lasers are tiny! Gave me a reason to buy some new screwdrivers though.
    RIP Bucko
  8. #28
    Aug 2006
    Massachusetts
    I have like every size and shape of screwdriver ever needed. I have like any tool I would ever need. It all started when I came here. I seem to have tools exactly made for doing this. I also decided to use my lightscribe drive. It was only $30. And when I got it, I bought 2 of them, and then decided to give one to my brother/ So I'm taking the one I gave him, so I won't even miss it. Maybe I'll make a worklog out of this.
  9. #29
    Retrosmith Mach's Avatar
    Texas
    150mW? This is from a friend who just built one. He says that he can melt plastic and heat shrink tubing but the focal length is only about a foot.
  10. #30
    . Spawn-Inc's Avatar
    Feb 2007
    how long does it take to light a match or melt things?
    Sound: Logtiech Z 5500
