Heya, just wondering if anyone knew how to make a custom volume knob/dial. Trying to put together an HTPC style case concept. Thanks.
You could take an existing knob, pull off the knob part and sculpt something out of Bondo or whatever, just so long as it's something that won't shrink too much to where you can't put it on the metal part... pull a knob/dial apart and get a little creative, this shouldn't take too much thought to figure out what to do, good luck!
My Webcomic: www.fknsrscmx.com
My Myspace Music page: www.myspace.com/ryokenryagnaroth
My Last.fm page: http://www.last.fm/music/Ryoken+Ryagnaroth
My deviantART page: www.ryoken-ryagnaroth.deviantart.com
My Weblog: gremlinbutts.blogspot.com/
Or you could just buy one of these and be done with it.
Thats cool, I might consider that now, lolz.
Anywho, I was thinking of getting a knob for my case, and I were to do it myself, I was wondering how I would go abouts hooking up the knob to the computer and have it change the volume (i don't know what i need to make the connections happen). Thanks!
Use a holesaw to cut a round piece of plexi, bondo the hole in the center to make it fit onto the control pot shaft, paint it a solid color on the front and leave the back clear, and use a dremel to cut a notch in the front to show position.
Then, backlight that mofo. The notch will light up, and you can even sand a ring around it to make that light up too, but the rest would be a solid color.
THAT would look sweet. Hmm.. makes me want to try that myself now...
It really shouldn't be too hard to make a volume knob. I think the easiest way (and the way I've been thinking of doing it on my own PC) is to use the existing volume knob for your speakers and moving it to the case and just extending the wires to the speakers.
I use the Logitech X540 speakers on my PCs (I have two of these sets) and they have a hard wired remote for the power/volume/bass controls.
The X540 speaker system:
My plan was to cut off the controller and mod it into the case, then use a parallel port style connector in the back of case so that effectively all I have done is extend the existing connectors and the parallel port is just used as a simple plug to hook it all up.
Some keyboards have volume knobs also, that should work too.
I tried that too. I use a USB interface for my cordless keyboard, so I tried modding a ps2 keyboard for just the media buttons. Unfortunately when I cut off the rest of the keyboard circuit boards and just left the media stuff, it no longer worked.
As it was an old keyboard, it was no loss to try it out.
Hey guys, sorry, maybe I led you all in the wrong direction, but its not the actual "volume knob" im having troubles with, its the connections to make it turn and actually make it adjust the PC's volume (the wiring and stuff) xD Thanks for the input though! 8D
ok sorry about this but... is any one lol'ing with all these talk about knobs hahaha
yea i know im imature
