When I mounted my new CPU heatsink on my new Athlon X2 4200+ I used my new arctic silver paste.
I had never done this before and have no clue if I did it right. I understand too much is as bad as too little. I put a thin even coat over the processor and slapped on the cooler before bolting it down.
Now, one of the cores of my processor consistently runs higher than the other when idle: 35 degrees vs 31 as I sit here.
When pushed by Orthos for twenty minutes both cores rise pretty swiftly to around 60 degrees and then stay there with 1 degree fluctuations up and down. When I stop Orthos within ten seconds both cores drop back to 40 degrees within 15 - 30 seconds and back under 35 in two minutes.
I am wondering if the different core temps when idle may be because I have not equally cooled them in my efforts at installation or if it is quite usual for two cores on the same chip to run at such different temperatures.
Thoughts, help, advices? all welcome
