I've heard TEC coolers can cool CPUs below 0 °C so I was wondering how do you solve a condensation problem, cause you probably don't want water near your CPU.
MBO: ASUS M2N-SLI Deluxe
RAM: 1 GB
CPU: AMD Athlon 64 X2 4200+
GPU: 7900 GT
HDD: 320 GB
I found this review while looking for a review fir a Swiftech MCW-60.
http://www.mvktech.net/content/view/1978/39/1/5/
have a look at the bottom of the page and you can see they are spraying the mobo with a condensation spray. (if you cant see it it's at the bottom of page 6). Page 7 gives you a more in depth explanation of how to prep the mobo. This should hopefully answer your question. You may also have to apply the spray to the GPU just in case.
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
