Can anyone help me with this ? Its driving me nuts. Almost every couple of minutes it happens. It never happened before and my distance between the router hasn't changed. ( 2 ceilings + 2 walls at about 3-4 bars.)
- Computer-Geek
Your router is overheating.
Weird I guess i will have to check it out. Now it wont even give me an ip address anymore. So i'm on some neighbors internet. I will let you know if i can fix it hopefully.
- Computer-Geek
What is the make and model of your router, and your network adapter?
Its a verizon westell versalink 327w, network adapter is a Broadcom 802.11b/g WLAN thats all it says in device manager. Dont worry about the 1394 net adapter.
This is the message I get after connecting to it. Once i got into the router page but i didn't know how it happened ><
- Computer-Geek
Perhaps uninstalling the software completely and reinstalling is the solution?
Mine was doing the same thing.
Read into the manual if you don't have it download it offline. I had to select extend range and set the wireless channel to auto. . my phone was disrupting the connection; I believe.
EDIT: More than likely the conflict "1394" is causing the problem right click and disable it and reboot.
I agree with Crenn that the router may be overheating, I'd also try changing the channel on the router to something other than 6 (auto/default) as it's possibly conflicting with someone else's wifi.
I finally got it fixed! It was strange I enabled UPnP which reset the router & now i'm connected I also disabled the 1394 network adapter which let me get into my router before this. + rep to you all.
How can I get my speed up ?
Edit: I still have that question but changing to channel 1 has helped a bit.
- Computer-Geek
I'm glad you got yours working but I still have the same problem. One of the problem is my wireless home phone interfering, but even when that's off it randomly disconnects. Then when I go to connect the network shows up and it connects but it says "Connection to local only".
I think I might have posted this before and I tried resetting pretty much just about everything since everyone recommended it.
I tried your fix, but UPnP is already enabled. Does any one have any ideas?
-Indybird
EDIT: I hope I didn't hijack your thread, I just thought I'd bring in my problem since it is very similar.
My Reviews
Logitech G25 // Razer Barracuda AC-1 // Gateway FHD2400 // Logitech G9 & ID Grip // Xbox 360 HD-DVD
Scythe KAMA-Meter // Sceptre X20WC
no problem i still keep getting disconnected then reconnected though.. but the icon never changes when i get disconnected.
- Computer-Geek
