Results 1 to 10 of 10
Thread: cd rom not detected?
    A big old Tease Apparently DonT-FeaR's Avatar
    Sep 2006
    Australia, south australia, Gawler
    Default cd rom not detected?
    in my efforts to get moditor finished i changed the cdrom from my system and plugged it all in and thought it should work
    what did i forget?
    you tease!
    Ride on, Bucko. FuzzyPlushroom's Avatar
    Jul 2007
    Live Free or Die, bitches.
    Default Re: cd rom not detected?
    You sure it's a working drive? If it works fine in another machine, make sure the ribbon cable's plugged in correctly on both ends, and that it's not damaged. If that doesn't do it, check the jumpers on the drive, especially if there's another drive on that IDE channel (on the cable).
    Quote Originally Posted by Mitternacht View Post
    Everyone else had quotes, and I didn't. I figured the next funny thing I see I'd throw in my sig.
    Quote Originally Posted by Luke122 View Post
    Jon, the whole post is about building a bong that changes its own water.
    Gee, it damn sure took me long enough to find and add the origin of the first quote...
    Sep 2006
    ok its brand new and sata so yea lol
    you tease!
    Does the drive open/close? If not, no power.
    Is the HDD sata too, and is it working? If so, try powering down, swapping ports, and rebooting.
    If not..
    Could the SATA controller be disabled in bios?
    Sep 2006
    it opens
    ill swap them over later tonight
    the hdd does work it is this pc
    swapped over the sata things and still doesnt workk
    you tease!
    Banned Eclecticos's Avatar
    Apr 2007
    Florida
    Are you using one of those sata power adapters? May want to try another one ive had several of them that created a short, some of them were soldered inside the connector in the wrong location. May want to check it out. I would also check to make sure the sata cables are not kinked or damaged at the ends.
    Sep 2006
    my friend reckons he may be able to fix it so ill talk to him later and get back to you thats for the help
    rofl never mind its been there the whole time i didnt see it
    everyone post you idiot!!!
    you tease!
    Jun 2006
    The Dairy State...
    ...Um, wth?
    Are there drivers that you may have forgotten to install? And what exactly doesn't work about it?
    RIP Bucko
    Sep 2006
    no it works now i didnt see it in my commputer
    you tease!
    Apr 2007
    Florida
    Great to see everything works now.
