Results 1 to 5 of 5
Thread: Need Some Quick Help
    Windows 7 Fanboy Datech's Avatar
    Nov 2008
    Atlanta, GA
    Default Need Some Quick Help
    Alright guys, I must have done something horrible recently cause Karma has come back to bite me. I'm posting in the Chatterbox cause I need to get this install done tonight, and this can be moved to the appropriate forum later.
    I'm finally installing Win7 on my big rig, after having absolutely 0 problems on six other Windows 7 upgrades. However, I pop the install disk in, boot from DVD, get 3/4 of the way through the initial Windows is loading files, and then I got blind sided...
    0xc00000e9: An unexpected I/O error has occurred.
    Google isn't terribly helpful, and there seems to be no direct solution. Here is all the information I can give you.
    • System Specs is in the My System information, with one 500GB WD Caviar Blue, and a 250GB WD as my second.
    • Installing Win7 Ultimate 64 from an MSDN download and burned to DVD. I haven't used this disk on any other installs yet.
    • Unplugged all USB devices, down to only my keyboard
    • Tried both hard drives plugged in, and each one separately
    • I have tried both the HDD and DVD drive in the SATA1 port with the other in SATA2.
    • I have had 0 noticeable or discoverable problems with any hardware in Vista Ultimate 64 bit.
    • I don't have a lot of peripherals and equipment to begin with, but I'm using just my graphics card, hard drive, DVD drive, CPU, full RAM, and of course PSU and mobo.
    Things I haven't done:
    • Used another optical drive
    • Used only one stick of RAM
    • Used another install disk
    Unfortunately, I don't have another optical drive to use. As I am waiting for responses, I will be trying one stick of RAM in each of the four slots, and will be burning another disk as a last resort.
    Please please suggest anything and everything and ask any other questions you may have.. I work from home and if I don't get this install done tonight I wont have another chance for about a week. For a techie guy, I'm getting super frustrated that I can't figure this out. Thanks in advance boys and girls.
    I would really like my Thermaltake prizes... Thanks everyone for my wonderful prizes!
    Nov 2008
    Atlanta, GA
    Default Re: Need Some Quick Help
    K, nevermind, it was apparently the disc. I reburned it at the slowest speed, and so far it is working like a charm. If an admin sees this feel free to move it to the appropriate forum. Thanks for the look guys, and hope my solution helps, lol.
    woy...collokweee...weeble weeble blaaaat artoodeeto's Avatar
    Oct 2009
    Simi Valley, California, USA
    you know it's funny, my very first thought was "did you try a different dvd." If there's one thing I've learned in all my years of building/modding/troubleshooting...often times the solutions are the dumbest, last things you'd ever think of. Hope that worked for you!
    Quote Originally Posted by ElevateThis View Post
    I'd mod my dog if i could.
    (Steam me.... that sounds bad >_<)
    Jun 2008
    MA
    did you try the disk you used for the other installs?
    Mar 2007
    Aiken, Sc
    Moving per Datech's request
