That's all beyond me.....
BTW, I'm waiting for the case to come in from Newegg. It was supposed to arrive on Friday, but UPS shows it as still in transit
WH1T3 0U7
Modified Thermaltake View 37
If you're trying to remove the white border in the Sketchup model you need to use an image editing program to delete the white then save the image as a .png so that the area around the crest is transparent. Then when you put the image into your sketchup model it will allow the green to show through. You may have to colour the back of the side (aka go inside the model and fill the panel with green to have it show. It's the process I found worked the best for showing an etch on a window. Give me a message if you want me to put a tutorial together.
TheMainMan
You should have a turoial here on TBCS, but I'll never figure that out anyway
WH1T3 0U7
Unless you need the model to be 100% accurate, and as you've said you don't, it's probably not worth it. Even with a tutorial (when I get around to putting one together) it's a finicky and long process. The only reason I went to the trouble initially to figure it out was because I needed to compare multiple window designs.
Love the design, can't wait to see it come together. I hate waiting for packages too
TheMainMan
That's OK, I've got other projects in my head while I wait.
WH1T3 0U7
The case arrived after 5 days of ordering
Then I stripped it down
And got rid of the Silverstone logo
Next, I painted it green
On to the left panel
I'm turning the "Z" in Zelda into a window
First I need a stencil
I always cut from the inside out as to not ruin the outside of the panel
I usually use a ruler as a guide when cutting
And after 10 minutes it's cut. Although it's still a bit rough
WH1T3 0U7
Looks great, that green is the perfect colour. My S.O. saw this and will be picking up the N64 from her parent's house the next time we're there.
TheMainMan
I moved on to the top panel where I took it apart
And cut away the excess
The top mesh is getting a face-lift too. First I got rid of the filter which is really more of a way of slowing down exhausting air
Then I gave it a quick once over
Once it was all dried I reassembled it
The window panel got a thick sheet of paint
Then the doorbell rang with my first prop. I still have to mount it though
Then I cut a new stencil
WH1T3 0U7
Looks good! Great progress.
TheMainMan
