Hello everybody...
I'm currently painting my case... I don't have a picture of it at the moment, I cant even remember the model number to provide a stock picture... I can tell you that it's a pretty basic Antec mid-tower ATX case, it used to be painted dull black with a silver/gray plastic front, no window...
I have it sanded with 220 then 400, primered once, then sanded again with 400 then 600... I plan to give it one more coat of Rustoleum Auto Primer... I've kinda been following this link http://case-mods.linear1.org/case-mo...r-case-part-1/
But now I'm not sure if this is the way I want to go, or should go... I'd really like to be able to get a nice metal flake job that is also very reflective, but as I understand it now, metal flake wont give the mirror effect, and Lacquer is about the only way to get it to mirror... Is that correct?
For metal flake, this is the paint I'm considering (probably blue or orange) http://www.amazon.com/Dupli-Color-MS.../dp/B00099C9QU
For Lacquer base mirror finish I found this http://www.dickblick.com/products/mo...-spray-paints/
Do I sand the last coat of primer before applying my first coat of color? And does that change based on whether I go Lacquer or Metal Flake?
Which way do you think I should go from here?
