does anyone know of a canadian webiste where i can get a hold of pink cathodes or LED's. my fiance wants me to mod her comp, and she wants pink. anyone?
I bought some 'red' ccfl light from AC Ryan, although I asked for red lights and the box said there were red lights in it, when I first turned them on they looked very pink to me... I've painted some parts in my case and made sure you didn't look straight into the lights and now the lights look more red. But if you want pink, just place them somewhere you can look directly into them.
Also I bought some rounded IDE-cables which also were supposed to be red, but the dude in the shop ordered UV-red cables for me... with no lighting they look VERY pink... In my mod I spraypainted them so they were red again...
OMG i had exactly the same thing! I sent them back becasue i was sure it was a mistake, but the next ones they sent where the same. Funny thing is, if you take a photo of them they look red in the photo!Originally Posted by silverdemon
I didn't have enough patience to send them back, it took months before my parts arrived... and you can judge yourself if the lights look red or pink on the photo in my signature
It's quite well knows that lots of red parts come out more on the pink side. It's expensive for manufactures to use large amount of dyes, and you need lots to get deep reds...
I believe streetglow makes pink neone. They also make a converter so you can use neons in your PC. hope this helps.
I found at least one at the store I buy from...
http://www.ledsales.com.au/cart.php?...category_id=45
Well, FWIW I noticed with my 5.25 drive light thing that when the blue and red lights are on together it comes out pink.
Yea i was going to suggest a mix of red and blue make a pinky purple colour (check out Defyants HP RES 2 Project) Beat me to it lolOriginally Posted by xmastree
you can buy white cathodes and use either (if you have access to it...not too hard to find) pink gels for stage lighting...or the much cheaper and similar...pink wrapping material....the clear stufff that is.....if you seen crimsonskys book...youll know what im talkin about
