I have a few questions about wiring. Part of my goal for my first mod is going to be wire management. I want the inside of the case to be as cleas as possible and I know this will require some careful wire management. Now looking at my current PSU and the wiring for it, I noticed they are not the longest wires around.
I am wondering what ya'll suggest for either extending the wires or other options to help manage the wiring. I do plan on using wire sleeving also. If you do recomend wire extension, what are some good places to look for wire.
I am also hoping to work some lighting into the case. Looking at probably using LED's unless you have a better suggestion for a 1st timer. Also, do you know of any good tutorials for wiring the lighting into the PSU?
