I've been lurking around here and on some other modding sites for a while now, but I just didn't have any money to build anything, so I didn't post. I've decided that I may as well get started, then deal with money (don't question my logic...)
anyways, this is a military / heavy industrial styled case. I was looking around for old army radio equipment or something, but it proved to be way out of my budget...then, I found a solution:
Its some sort of military ammo crate, and it only cost me $13!
(thats my current gaming rig behind it btw...)
The dimensions are a bit odd, but I did do a bit of measuring and test-fitting with parts I have laying around:
unfortunately, it a short case ( it looks taller because I'm measuring with a microATX board, and I plan on using a full ATX system here), so the only way I could find to put the power supply on the back panel without having crazy airflow was to put it behind the mobo I am wondering about big graphics cards and the card locking screws though...will there be enough room? idk...
anyways...time to measure more stuff..
overhead view - airflow/fans, psu, mobo, cards, hdds (above psu for now)
and...the optical drive spacing is just about perfect (especially as the drive I'm measuring with is a fairly deep one. success!
hmm...other notes... I don't want to cut into this any more than I have to, and I'm not adding any more access...that'll be some of the challenge just getting everything accessible through the top only.
anyways... I plan to mesh the back bottom bump-out on each side to allow air for the GPU(s?) (probably 8800gts 320 oc from foxconn) and psu. replace the backplate entirely with a custom one, put a 120mm fan hole in the front, cut an opening for at least one optical drive centered (horizontal), and a card reader and fan controller vertically on the edges of the front...
So yeah... I've been thinking about it alot... any suggestions to improve the layout... because the dimensions kinda just suck inside this thing...
anyways, thats the plan. we'll see how it actually turns out.
EDIT: replaced pictures with links to save the formatting...those were even bigger that I thought...stupid good camera xD
