My Reviews
Logitech G25 // Razer Barracuda AC-1 // Gateway FHD2400 // Logitech G9 & ID Grip // Xbox 360 HD-DVD
Scythe KAMA-Meter // Sceptre X20WC
I don't think anything DOS based is going to run modern printer. I don't even know of any programs still made for the DOS system. But I've only been really back into the in depth computer scene since I found this site.
So they are opposed to running linux then? This would allow them to install a wider variety of GUI based utilities.
How many users are accessing the database? How big is the database? Importing the data into Access or SQL may be the way to go, depending on size/format.
Access can create a pretty nice interface, since all the forms are created using a WYSIWYG interface.. think "drag and drop". SQL is probably overkill for this project, and it's definitely more costly, whereas Access is included with most versions of MS office.
I was think of suggesting that but I know nothing about Linux based systems. Been meaning to down and tinker some but never remember to. hmmm. Might be something to look at seems lots of people like it here.
I was only suggesting Linux because it would be free, I agree that Access is a better choice but don't you need windows to run it?
Yes, you would need Access (and therefore Windows) to run the DB. My understanding of this project (and I could be wrong here) was that they were moving to a GUI OS to get away from DOS, and limitations of DOS accessing newer printers.
The more I think about this, if the PC's already have Windows on them then the printers can be installed there, and the LPT port can be captured to redirect printjobs, essentially allowing the DOS app to print to new printers.
...thoughts?
Yup, Access come with the Office Pack they sell. I think through MS you can buy just Access but don't quote me on that one. I never know what MS is think nowadays.
If you just want to make their app work the way it is, try FreeDOS;
http://www.freedos.org/
They may have updated some of the drivers or at least you can print to network printers letting the printer host control the printer...
ok, im sorry for not making this very clear but the computers are running windows XP but the program is in DOS. Access sounds like a great idea; i had a class on that my freshman year. Just in case though, I'll tell you what they'll be using it for.
They own 7 gas stations and need to manage gas, mini-mart items and profits and be able to print it out in an organized manner.
Thanks for all the help!
I'll get back to you once we try everything out.
My Reviews
