I'm still going to try. At least it'll be cheaper if I do my own
WH1T3 0U7
Modified Thermaltake View 37
I'm in the process of deciding how thick is too thick. . . .? A normal cooler is about an inch or less and that's plenty for a DVD drive and a fan, but do I want more? Do I really plan on traveling with it and trying to stowe it??
I work on it more tonight
WH1T3 0U7
i would have to say anything thicker than your laptop closed is too thick... 1:1 thickness max imho... what about an external power source?i have a feeling fans + DVD + w/e is gunna eat your battery and such... i take it portability isnt the key thing here?
I finally found the right starter piece: Here
It's a 3 tier file holder that mounts on a wall.
I only need one of the three, so I cut it down...and added the DVD drive
Then I painted it black.
Next I added this cool BBQ mesh.
I also added some sound dampening material to the back of the DVD.
The last thing it needed was feet.
Here it is:
I'm not done. I still want to add a fan
WH1T3 0U7
Pretty sweet.
With all the mesh would the fan be needed?
If you still wanted the fan, what about a temp operated fan? That way the fan wont always be on unless you are stressing the laptop.
On Backup:: CPU- Q9300 Stock HS/F :: MB- Intel board :: RAM- 4 GB Corsair Dominator DDR2 1066 (2x2GB) :: GFX- 8800GS HDD- 320GB OS; 1x2TB Storage :: ROM- DVD-ROM :: PSU- Antec 48W :: OS- Win7 x64 :: CASE- CM Centurion 590 :: MON- Dell 1708FP :: MOUSE- Logitech G5 ::
