I had my PC replaced at work. I work with two identical HP1740 monitors. For some reason since the monitor replacement I can't get the resolution to work correctly on the second screen.
The monitor lists its "optimal resolution" as 1152x864, but this resolution makes text hard to read. When I reset the resolution to something bigger, instead of filling the screen with a bigger picture it just displays less of the image in a sort of window, with a black bar all the way around it. Text is still the same size.
What makes this extra confusing is that it only happens on the second monitor. The first screen that seems to be working all right is running off of a VGA signal directly from the board. The problem screen runs DVI via a DisplayPort to DVI adapter.
I've only worked with this one night and I've got a headache, anyone have any ideas how to make this thing full-screen at a lower resolution?
Thanks!
