Results 1 to 6 of 6
Thread: MacBook Pro issues
    Oct 2008
    MD, USA
    Default MacBook Pro issues
    Before anyone freaks out, no, I did not buy a Mac. It's for a friend, I swear. ..no, but seriously, I didn't buy a Mac....
    Anyways, I haven't seen the thing yet, but apparently the onboard keyboard, touchpad, and ODD have stopped working, but when you plug keyboard/mouse/etc into the USB ports, they work fine. I'm guessing a loose ribbon cable, but anyone who has more experience with MBP's have any other ideas?
    --Benjamin Franklin
    rawrnomnom diluzio91's Avatar
    Jan 2010
    Default Re: MacBook Pro issues
    definatly loose cable... with those things it always is... They never break... they just unclip... I would go teardown route, or take it in if its less than a year old... and dont worry... I "didnt" buy a macbook pro either...
    Not dead yet
    If it's a pro, you have to remove every visible screw on the casing, then pop off the top part (keyboard/touchpad are all one piece). The ribbon cable for the keyboard/touchpad connect dead center in the mobo, right under the keyboard. The ODD connection should be separate from that, so if two of them are disconnected, I'd either suspect it was opened and not reassembled right, or it was dropped/hit hard enough to disconnect.
    While you have it open, do a visual inspection on the components on the right side of the mobo (approximately where the enter key is on the keyboard), and look for heat damage.
    I've only opened two macbook pros, both of which were recent, and both of which were failures due to heat.. and both failures were within an inch of each other.
    Jan 2010
    lol... i installed SMC fan control for mine... helps alot
    Not dead yet
    I did that on my Mac Mini.. HUUUGE difference! 80'C? No thanks.. it maxes at 62'C now.
    Jan 2010
    I found out that the fans are just as quiet around 3000 rpm as they are at the default 2000
    Not dead yet
