Ok I recently built a new rig...
Was intel promotion
Intel Dx58SO (dead on arrival) so I bought an Asus p6x58d-e
Intel I7 940
Intel 160g ssd
I also bought
2x3 ddr3 1600 gskill ram 1.5V
Evga 480 Sc
Corsair hx1000w
2 wd 2tb drives (raid 0)
2 segate 2tb drives (raid 0)
Corsair 800d
Corsair H50
Now the problems
First the ram... It randomly changes.. from 2gigs 4gigs and 6gigs.. its always loses the channels in the same order.. slot 1 slot 3 slot 5.. Slot 5 goes frist then 3... I tried takeing the ram out moveing it around but it would randomly screw up.. I even tried reseating the cpu Nope still happens right now Im underclocking the ram to 1066 to see if that helps... who knows tried xcp ect tried overclocking tried adding more voltage to the ram...
Now the other problem.. I rest the bois to defualt settings.. which turns raid off... Then I booted windows and went hmm raids off lets just restart... I turn raid on and now 1 disk has failed in the raids... for both of them... which is a pain because I deleted a bunch of data that I put on them.. (was cleaning up files off other hardrives ect) Anyone know how to recover the raid it sees 1 of the hardrives as a normal disk (non raid) and 1 drive is raided still If I delete the raid then rebuild it it wont work.. if I edit it it wont work this is the second time I had this same problem.. Dam windows 7 ulitlmaite seeing my hardrives...
