Results 1 to 5 of 5
Thread: Quad Bay Reservoirs?
    50 Custom PC's in 10 Years! TheGreatSatan's Avatar
    Southern IL
    Default Quad Bay Reservoirs?
    Do they make any reservoirs that are bigger than dual bay? Like maybe Quad?
    NEW GENESIS
    Modified Azza Genesis with an Intel i7 2600K, Gigabyte Z68X-UD3H, 32GB (8GB x 4) Corsair XMS3, 960GB Crucial M500, 240GB Sandisk Extreme, 1275 Watt Thermaltake 80 Platinum Modular PSU, Gigabyte GTX 780 OC 3GB, and a Corsair H60
    Overclocked Lothair's Avatar
    Nov 2010
    United States
    Default Re: Quad Bay Reservoirs?
    I'm almost certain that they don't exist. Not incredibly hard to make yourself, though? And it would be cheaper, too. You could even get crazy with the design, like do a waterfall reservoir or something.
    Oct 2008
    MD, USA
    /\ What he said.
    OOC, why do you want a quad-bay res? I can't think of any reason other than aesthetics.
    --Benjamin Franklin
    Jun 2009
    Birmingham, AL
    Danger Den does a five-bay dual D5 reservoir, though it will be in small quantities and be rather expensive (about like two reservoirs and two D5 tops, really) but its performance is amazing.
    Southern IL
    It would be for aesthetics only. I really just need a plexi box that has the measurements to fill four 5.25 bays.
    This is for a distant project.
    NEW GENESIS
