Results 1 to 6 of 6
Thread: Adding a motion sensor?
    Over 75 Custom PC's in 20 years TheGreatSatan's Avatar
    Southern IL
    Default Adding a motion sensor?
    Anyone know how to add a motion sensor to a PC, so it does "x" when someone passes by?
    WH1T3 0U7
    Modified Thermaltake View 37
    Jun 2006
    In the Redwoods
    Default Re: Adding a motion sensor?
    A long time ago I used a serial connected motion sensor (rs232) to trigger a sound file when someone walked by my office door. It was really easy to program. At the time I used C, but there is probably an easier way now using basic or something simpler.
    Aug 2005
    Sunderland, Tyne & Wear, UK
    I looked into this a while ago when planning K-9-PC and came to the conclusion that buying a super-cheap security light was probably the way to go, and having it trigger an arduino to do whatever you want - which in my case was make the dogs ears move whenever someone walked by.
    Retrosmith Mach's Avatar
    Texas
    A PIR sensor from Sparkfun or radioshack hooked to an arduino. Sparkfun makes an ePir that looks interesting.
    http://www.sparkfun.com/search/resul...&what=products
    See here for the code: http://www.arduino.cc/playground/Code/PIRsense
    I have one hooked into my berserker mod where its used to trigger the lights to change color and play an mp3 file of a Big Daddy growling when someone get near.
    Depending on what you have in mind, this may be easier.
    Southern IL
    I was wanting to make it make an evil growl. I wonder if I could just buy one of those Halloween things that have the motion sensor built in that growls already. Then gut it and transfer the parts to a PC.
    WH1T3 0U7
    A.B. normal msmrx57's Avatar
    Jan 2008
    Western Wisconsin
    That would probably work fine, if you know where you can buy Halloween stuff this time of year.
    Now, off to the basement to do some fiddling with the rods and such.
    so far left of center i'm in right field
