I need a PSU plug... Like the plug that is in the back of your PSU. I need one for my lite brite mod because I want to be able to take the cable out. Any ideas where I can find one online?
no not the cable. The actual plug that it goes into in the back of your PSU.
But you lead me to this.
Thanks man. I saw its called IEC.
Don't have a dead PSU floating around your house or someone with a dead PSU that you know?
If you do could just chop and change.
Think Fuga is looking for something like this one...
http://www.tripplite.com/en/products...xtModelID=2193
Nope. What I linked is what I need. I'm installing fans and lights in the lite brite box, hooked up to a single pole double switch then going to the plug I linked. Then I can use any PSU power cable to power it.
Buy a case for modding that comes with a lame PSU that nobody with half a brain would use. Chop it up for parts.
