Okay, first of all i want to say that there are many ways to cool your pc. You can try using alot of fans, Heat spreaders on certain components, water-cooling, or having no case at all- http://www.extremetech.com/slideshow...1&po=10,00.aspAnyways...water-cooling is a big fad right now, but probably too expensive to be practical for an average desk top. So i was just wondering as usual and i came up with a cheaper version of a WC system. Here it goes: basically you have two PVC pipes, a 1-inch tube placed inside of a 3-inch tube.The bottom is covered and the space between the two pipes is filled with cooling liquid. Top cover has a hole (x2) looking down into the liquid-filled gap and a 1-inch hole looking into the 1-inch pipe. Now, to cool the liquid, you take a tube,with a cover at the bottom and a removable top lid. you fill the tube with ice and slide it into the small tube. To pump it around, use a small electrical pump hooked up to the hole looking into the gap.
p.s. if this sounds like a bunch of jibberish, i might try to make a blueprint
p.p.s. I'm a newbie so this thread might sound really stupid
