is it possible to have 2 or more psu's on a computer.
ie: a seperate 250 watt psu for a RAID 5 array
"We did not choose to become robots. There was an accident in our studio. We were working on our sampler, and at exactly 9:09 a.m. on September 9, 1999, it exploded. When we regained consciousness, we discovered that we had become robots."
-Daft Punk
yes
Yeah, and you don't particularly need two PSU's just to run a RAID array. I'm pretty sure, as long as you have a quality PSU (none of this aspire/apeiva **** or anything like that) with enough connecters it'll handle it just fine.
Now, I have seen an instance where two PSU's were needed, in my dad's computer, because he's got like 3 optical drives, a high-end GPU, somewhere in the neighborhood of 10HD's (IDE, SCSI, and SATA combined) and some other insane cooling crap.
You can also buy separate PSU's that are made especially for "High End" GPU's. They are also designed to fit into a 5.25 bay. That will free up what? 140-300Watts? That should be enough to run a few more HDD's or Optical's right?
-SnowFire
ok, i know i could get a single psu, but its mainly for bragging rights
-Daft Punk
Err... Guide.
(Funfact: I spelled it "guild" agian in this post but caught it)
Bragging rights? Two PSU's? Never heard this before.
I think the only thing you get from another PSU if it's unnessacary is one less outlet, more heat (=less bragging rights, heat=bad), and a heavier computer.
Not to mention the power wasted. The only time i've seen anyone use 2 PSU's is slythefox, but he's running a huge amount of drives.
-Dave
BTW, it's slytherockThe only time i've seen anyone use 2 PSU's is slythefox
When I build this dual PSU, the common Wattage was about 420W, now you can find good reliable PSU without the mod. But if you want a cooling system that stays on after your turned off your comp or want your lights on too, its can be usefull. But in other case, you better find a good one, just as I did.
