Login:
Pass:
Forgotten Pass?
Forums
Forum Home
Search
Today's Posts
Members List
Calendar
Search
Google
Search TBCS
Search the Web
Follow Us On
Airbrush Tricks
Computer Mods
PC Cases
Computer Speakers
Power Supplies
PC Mods
Water Cooling
CPU Coolers
Modular Power Supplies
SLI Power Supplies
Multifunction Panels
Cable Management
Gaming Accessories
RC Toys
Go Back   TBCS Community Forums > Mod Walk > TBCS Featured Worklogs
Reply
Thread Tools
  #1
Old 07-20-2007, 04:21 AM
|NQ|Squelsh's Avatar
|NQ|Squelsh |NQ|Squelsh is offline
Thinks spherical
|NQ|Squelsh knows what they are talking about when it comes to computers.|NQ|Squelsh knows what they are talking about when it comes to computers.|NQ|Squelsh knows what they are talking about when it comes to computers.|NQ|Squelsh knows what they are talking about when it comes to computers.
Default The Orb
Hi freaks,
after completing two Casecons (Reactor and CUBE) and making the 10th place on the German Case Modding Cometition I thought it would be nice to get away from the cubic cases seen everywhere. As I am a fan of straight geometrics, what would be nicer than a sphere?
TBCS is simply the coolest place in the web, when you want to see mods that go far beyond some LEDs and windows in a standard case. So I hope to find some helping "hands" in here with good suggestions and experience.
Hope you like my Orb
The basic idea is to construct some kind of Pacman or motorcycle-helmet that can open a visor driven by a motor. And to make it really challenging, I wanted the cooling-liquid inside this visor
I will start with some renderings from the plans I did:
I am not quite sure, if I will build the feet this way, because the Orb has to fit on my desk and with those feet it will be huge.
The diameter of the spehre is about 40cm, giving me enough space to hide all hardware, waterpump inside. Only the radiator will be outside of it.
As you can see, I planned two versions (in fact some more), once a realistic one and one I could build with unlimited cash
So, what do you think? Top or flop? Worth to spend time and money on it or rather a stupid Idea to build a spheric PC? I love to hear your comments!
---------------- EDIT -----------------
This is how far I am at the moment:
---------------- /EDIT -----------------
__________________
My CaseCons:
-=| The Orb |=- - - -=| CUBE 2 |=- - - -=| Reactor |=-
  #2
Old 07-20-2007, 05:50 AM
dgrmkrp dgrmkrp is offline
D'Oh
dgrmkrp knows what they are talking about when it comes to computers.dgrmkrp knows what they are talking about when it comes to computers.dgrmkrp knows what they are talking about when it comes to computers.dgrmkrp knows what they are talking about when it comes to computers.
Default Re: The Orb
You mean like having a submerged mobo or having a reservoir the shape of the visor?
I like the idea, and if you have the time and money to do it.. go for it
__________________
  #3
Old 07-20-2007, 07:53 AM
jdbnsn's Avatar
jdbnsn jdbnsn is offline
I Suck At Photoshop
jdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modderjdbnsn Elite Modder
My System
Default Re: The Orb
Wow, very original design I agree that the feet are going to be a bit large but all in all it looks great.
__________________
http://www.quackwatch.com/
Originally Posted by Collinstheclown View Post
1h 44m 50s wasted... Now I know how sperm feel.
  #4
Old 07-20-2007, 08:45 AM
Eclecticos's Avatar
Eclecticos Eclecticos is offline
Banned
Eclecticos is an unknown quantity.
My System
Default Re: The Orb
Kewl! Can't wait to see the build on this thing.
When you get around to building the Unlimited cash model you could put your orb on a LynxMotion Hexapod. Just a thought.
  #5
Old 07-20-2007, 12:40 PM
|NQ|Squelsh's Avatar
Thinks spherical
Default Re: The Orb
Well, I have to admit that I have been working for about two month now on this project and that I put a lot of time and quite some money in this project. So I'm going to write a log about the work that is already done, show you some big set-backs I encountered and how I solved them.
And hopefully in some month I have a finished Orb and a nice worklog
First of all, here is a little sketch and some drawings I did:
The visor is made of two quarter-spheres, one a little smaler than the other. Glued together with about 5mm of space for the water. This will definitely be the hardest part to create...
__________________
My CaseCons:
  #6
Old 07-20-2007, 12:47 PM
elbarto241 elbarto241 is offline
AP BC Calculus = Headaches
elbarto241 is friendly and helpful.elbarto241 is friendly and helpful.
Default Re: The Orb
those are some really nice renderings, i like the idea of a sphere instead of the regular box looking PC. GL!
__________________
Intel Pent D 2.66Ghz| 2Gigs| 18x DVD-RW| 200, 40 GB| 550W ATX| Zalman 9500
  #7
|NQ|Squelsh's Avatar
Thinks spherical
Default Re: The Orb
One critical problem I had:
Where can one buy spheres with 40cm in diameter?
It took me about 3 month of hard search till I found a manufacturer of garden-lamps who sold a plastic lamp with exactly 40cm in diameter! So I ordered one. When it arrived I needed some tries till I figured out a way to mark an equatorial-line... The sphere had one open "side" which I needed to cut out. I finally drilled a small hole and attached a string in it with the lengh of 1/4th of the perimeter. With this I could draw the equator:
Here you see the mounting of the garden lamp.
My first try to mark an equatorial line.
The Orb sitting on my last casecon CUBE2.
All the red lines are only for orientation. The lines I cut out were marked with a thin cutter. You can see my tool for marking is made of a cable...
... fixed with a pinboard-pin.
Drawing the lines. I corrected them with a bending ruler.
The result:
Unfortunately the sphere is made in a way that the material has not the same thickness all over ): At some spots it's only 2mm thick and somewhere else it's 5mm.
Drilling many 0.5mm holes to get this special form where the hinge for the visor will be built in.
The case is made of three parts: One half spehre at the bottom, one quarter sphere for the top rear and one quarter made of plexiglas for the visor. Here you see the bottom.
This is the upper quarter with the circle that hides the hinge of the visor. It's not final in this shot. Has to be filed off.
As I mentioned above, the material-strengh differed a lot which led to a crack in the upper quarter, I had to fix with some plastic left from the mounting.
So far, so good.
__________________
My CaseCons:
  #8
Old 07-20-2007, 12:54 PM
|NQ|Squelsh's Avatar
Thinks spherical
Default Re: The Orb
Hey Eclecticos,
thanks for the hint with the Lynxmotion. I am studiing robotics and those are some nice toys (:
@elbarto: Thanx - I rendered a little movie. Will try to put it in here tomorrow.
Btw: Sorry, if my english isn't the best. Hope you can figure out, what I want to say
__________________
My CaseCons:
  #9
Old 07-20-2007, 01:47 PM
doesi87 doesi87 is offline
doesi87 is well known around here.doesi87 is well known around here.
Default Re: The Orb
This is simply great man. Subscripted and will definitely be watched.
  #10
Old 07-20-2007, 01:54 PM
rendermandan's Avatar
rendermandan rendermandan is offline
Modders block
rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.rendermandan might just be god.
My System
Default Re: The Orb
This looks pretty cool. Hope you can pull it off, Good luck!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Translate This Page
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
thebestcasescenario.com
