The Mustang case at work doesn't as good as anymore. It's really showing it's age and frankly looks boring next to the Steampunk Level 10 case.
So, I decided that we should replace it with something cooler, but I really don't want to do a whole new project just for a work case. After all, this would all be out of my pocket. I thought about possibly using a case I already had in my modding area and the Ark to did come to mind, but I don't think it would fit.
Then I remembered Bulldozer, but it's an AMD theme case and components going in it are Intel.
Then I thought, what about a repaint?
I looked online at other types of Bulldozers and found the military's D9. A green Dozer!
First I start with the intake mesh
Then the panels. I'm using an Olive color from Krylon
Then it was time to blast all of the rest
Once it all dried I starting putting it all back together
I was going to use a single 200mm fan, but didn't have one thin enough to fit here, so I went went with two 120's instead
The right panel is done so I put it back on
And I put the window back on the panel, but it's really hard to tell it's even there
