i have a 80mm fan mount in the back of my computer and a 40mm grill in the front but theres some problems ive run into
first the 80mm the mount is in the back where air is not very easy to flow to since its 5 inches from a wall and just below my psu which is kicking out hot air what should i do? would the fan even make a difference?
now the 40mm the grill is 40mm in height and 120mm in width i know its a mount because its got a place for mounts and they wouldnt just put a grill there for fun but the mounts are 40mm apart vertically but 95mm apart laterally? is it an actual fan mount? if so what kind of fan?
i ask this because my system is running hot and its old 40gb hdd and a 1.3ghz proc with a 100mhz fsb its been freezing up alot lately when i run the processor continuously at 100% and never comes back so i have to restart will the fans help? and one more question i know youll think im stupid but what exactly is overclocking and how do you get a processor to over clock because i think intel put a governor of some sorts on my celeron. and currently one more tidbit i have no fans in my case except dor the heatsink on the northbridge and the heatsink and fan on my proc
