I was wondering, since Im getting an Antec 900 soon and don't feel like seeing a big colored square of blue-lit plastic around the fan on the side panel, if it was possible to slim it down using a Dremel. Had some questions.
1. Would it affect air flow if I would cut all the exterior bezel of the fan but keep a small plastic line for the screws, as well as the plastic "legs" that holds the fan to the bezel?
2. Would it look good? Assuming Im using my patience and don'T rush through.
3. On a LED fan, would there be a way around this or I should keep another plastic ring around the fan so that the LED actually works?
I personally always liked the look fans had without the bezel, such as the stock Intel fans, and was wondering if it would look good.
Id "slim" a new CoolerMaster blue fan when I will have my new case soon, and since it's led I may sand the whole remaining so that it does not look clear. But of course I would try it out on an old black fan I have lying around, and make some test about the airflow. May eventually post a tutorial about if it ends up nice.
