Hey y'all, I have a 3.5" maxtor 500GB drive that once was my main internal drive, for 3-4 years or so, and is now an external since I bought an SSD a year ago. I usually have it standing up on its side rather than laying flat.
The last couple weeks, every once in awhile, it would sort of hiccup. Meaning it's plugged into the power, the USB is securely hooked into the computer, and out of nowhere the computer would lose the connection to it, immediately redetect it, and act as though I'd just plugged it in. Given that this only occurred once maybe every few days, I didn't think much of it. I usually noticed this issue after the drive had been on for at least a few hours; it gets fairly hot after awhile (it's in an aluminum enclosure).
Today...after it'd been on for I think less than an hour, and while I was working on a couple files stored on the drive (Illustrator and word files), it did that hiccup thing again, except it did it once, then a few minutes later seemed to get stuck in a loop of losing the connection and redetecting the drive. It also was popping up a message saying the drive wasn't formatted and would I like to format it. Of course I hit cancel...and I eventually just had to power off the drive. I laid it flat and turned it on again a little while later for a few minutes and it seemed fine.
Does it sound like the drive might be going kaput? If it comes down to it I *could* take it out of the enclosure and hook it directly to the internal SATA connection and see if it's ok, but I don't really have space in the computer case for it. So I thought I'd ask here first.
I don't really have the cash for a new one (I'd want a 2.5" 500GB sata), but I'll spend the money if my data integrity is at risk.
Appreciate the input!
