So I'm looking for tips, secrets and general advice on a few things pelxi. I have one of those scrapper things so you can leave that out. I can Google till my fingers bleed but I want to know what are other modders are using.
What type of polish are people using? I've heard car polish works good.
What type of adhesive do you use? Do you recommend certain ones?I heard Weld-ON is a good brand.
Any tips for gluing pieces together?
+rep for the help! Links help too because I can't just go out and buy this stuff at Lowes/Home Depot. I have to order it online.
I appreciate y'alls help!!
