This is the worklog of my R2-D2 casemod, which is a ultra-low budget project. So far I have spend about 120 dollars on it.
Basis of this mod is a written-off garbage can that I was told to get rid off. From the internet I gathered pictures of R2, and started my first dremel-cuts, based upon guessing the size*.
I am making this mod in three big chuncks; the Dome, the Body and the Legs. I am building all three simultaniously, so i'll be jumping from one to another all the time.
Body.
The base, an old garbage can, about to be thrown away.
Lets get an old PC case from the attic.
Quickly disassembled.
And what is left over , a mobo tray and a backplane.
Hmm, a bit too big. Gotta make that a bit smaller.
From the many pictures of the net, I estimated the lenght-width ratio, and decided to cut off a big chunk.
I used this pneumatic tool, sort-off giant air dremel.
For all you starting casemodders; always wear eye protection. Trust me.
Also used some ear protection, as the bin was working as a drum.
Thats off, now the sharp edges.
Lets try the tray. I see I have to fold the edges.
*let me get back to that guessing part. áfter I started, then I came upon Astromech and the guys from the R2-builders club. They kindly provided me with the original blueprints of the real R2. I found out, my R2 was 75% of the real deal. Also the blueprints were in inches. So now I am constantly recalculating the blueprint to 75 % and then from inches to milimeters.
The back, looking good.
For use as "vents" i dug up these ancient ( 1984 ) grills from speakerboxes.
Used the dremel to cut the hole for the vent.
Later on, I see the vents don't stick out at all. I made a small container to hold the fans.
I made it from Vikureen
My sponsor SpacePromotion provided me with two 60 mm fans with white LEDs.
Hmm... that doesnt fit because of the extra wires for those LEDs.
Bit of creative cutting.
LEGS.
A stack of MDF wood and some wood-glue.
Something like this.
First cuts.
Using the workmate and clamps the legs are taking form.
With some sanding they look now like this.
